PaulGS
I seem to be buying a boat that's been on the hard for a year and a half. It was properly serviced immediately before lay-up so do I now need to service it again? TIA
I sampled mine with a Pela to ensure it was bug-free before turning the engine over.I would be more concerned by the fuel. The boat I recently bought had only been stood for two months with a smallish 40l plastic tank however when I went to change the primary fuel filter I did not like what I found at all. I guess the filter was doing its job but the incoming hose was spewing a black gunge. I took the tank out and when emptied was full of rust bits and all sorts and then the inspection cover would not seal again properly.
Ended up buying a new tank, replacing all lines, and putting in a new Racor filter. Feel much better about the whole thing and glad that I did it.
That would have been false hope in my case. I don't think diesel bug was the problem or the worst problem if it existed. I filtered the fuel as it was coming out and the fuel above the bottom was fine but the amount of junk in the tank was amazing. For sure this boat will last me a good while but if if ever bought another then a serious cleansing of the tank would be first priority and I would probably just replace the tank anyway assuming access was sufficient based on this experience.I sampled mine with a Pela to ensure it was bug-free before turning the engine over.
Huge difference between a barn and the marine environment.
