eddystone
Following earlier thread on white smoke in the exhaust ( I should have done a search first!) the engineer thinks it (VP2002) has more serious problems. I'm not going to throw a lot of money at a 30 year old engine so it looks like a re-engine. A lot of the issues seem to be down to having to relocate ancilliaries. Based on the most likely choice of a Beta 25, wonder if anyone been down this road and knows the pratfalls!
I don't know which way the shaft turns on a Beta, but currently I have a 15.5 x 12 RH 2 bladed prop; on the standard 2002, Volvo advice is to let it spin in neutral which reduces drag; if I had to lock it off with a fixed prop drag would be worse than present so I might be tempted to go for a Darglow feathering prop, even more so if I had to get a new prop anyway. Hear you need to change the anode every 6 months though, which is a drag (no pun intended)
I'm assuming it will need new feet, new exhaust (hopefully to existing hull outlet), need a new Morse control anyway, some fiddling around to fit new electrics and switch panel, possibly new shaft and prop (as above) but can recycle existing primary filter/water trap.
I would guess that the Beta has more torque low down than the 2002 which should also help manoeuvrability. Just now need to see whether this stuff about "Boat Show prices" really applies if I'm not planning to go to one.
Also understand labour likely to be around £1500. The only DIY contribution I'm likely to make is fitting new insulation while the engine is out. What do you think an old 2002 should fetch on ebay (as a runner, which it is)?
