jimmy_the_builder
Hi Jimmy,
I don't know whether you've seen a Targa 40 with a letter box passerelle in operation. But as I understand it from a fabricator that asked to look at mine to check feasibility of fitting one on the port side for a client.
Fairline only supplied two T40s' with passerelle. The scope was very limited, in terms of length due to the locker being short and too shallow for three sections. This also meant a limited arc and raising angle. The other annoying point I was told was that the pump was too small and it took about a minute to extend just 5 feet.
If this is the case then I think you made the right choice. How would you have felt if you had spent £7K for something to wind you up even tighter.:encouragement:
Roger.
Hi Roger, no, never seen one working in the flesh. I didn't know the number supplied by Fairline was so small, tbh I'm surprised at that because I've definitely seen more than two with the option in the wild - maybe they are retro's? The OE unit was a Besenzoni, a PI374 Onda iirc, and you're right, it didn't extend very far - but it was just far enough to get you over the bathing platform and up to the quay. I didn't know that about the pump though - that would deffo be v annoying.
What I need, and have tried (and failed) to design, is a bigger bathing platform for the T40, with a clever two-way mechanism where the platform can lower a bit into the sea for that beer-on-a-directors-chair-toes-in-the-water experience, but also rise up maybe 500mm so you step _up_ from the companionway on the boat to the platform, and then it's just a small step up again to the quay. A bit like that Opacmare Transformer you see on the back of the big Ferretti's, only on a titchy scale.
