Raymarine wind instrument on the blink
Kelpie
15 May 2005
Afloat
My wind instrument has stopped showing speed, but still shows direction.
Any hints or tips on where to start looking? I've just looked up the price for a new transducer, I'm hoping this is just a faulty cable or something ?
Neeves
20 Nov 2011
Sydney, Australia.
Maybe something else completely
Do you still have three cups at the masthead?
Here the cockatoos, primarily white (and yellow crested) enjoy the tussle with removal of one cup.
Jonathan
geem
27 Apr 2006
Caribbean
Once you have checked the obvious, there is a place where bad connections develop inside the display unit. Take the screws out of the back and remove the back panel. It has a number of pronglike terminals that insert in to the pcb. Mine was verdigris-ed up here. Electra spray and all has been well since.
I now have a problem where the wind instrument work fine stand alone but when the plotter is powered up we get peaks of silly high wind speeds that are not real. Suspect the plotter is faulty and time for new. One of several faults going on
Kelpie
15 May 2005
Afloat
Thanks all, bit of a false alarm in the end. Turned out I'd accidentally switched to VMG mode. Coupled with a dirty log impeller which isn't spinning, it led to a zero on the wind instrument too.
So nothing actually broken, just a reminder to pull the log at some point!
geem
27 Apr 2006
Caribbean
Just fixed my over reading wind instrument. Was a bad data cable on the network. Swapped out for a spare. Also similar issue on Radar cable. Electra spray on connections seems to have d9ne the trick. Now got everything working again?
