Cantata
Raymarine ST4000 autopilot misbehaving
I have a ST4000 working through a tiller. It's maybe 12 years old, the instrument head had a new circuit board about 6 years ago (Raymarine standard repair if there's anything much wrong in one of their instruments, it seems) and has worked perfectly well until recently.
It started basically not working, the boat would suddenly veer right off course. Noticed that the compass readings were erratic, so I decided to re-calibrate it which I did yesterday - went through the procedure which all worked as per the manual, stored the new deviation and the compass bearings looked pretty solid and matched the magnetic compass, near enough. Tried it out immediately afterwards, and it appeared to work OK although perhaps a bit more fidgety that before.
Tried to use it today on passage in zero wind, and it went bananas again, basically it seemed to know the course it should follow but it was over-correcting all the time so we proceeded in a wild zig-zag.
The gain setting is as it always was. The compass readings looked OK.
I suspected a poor connection but they all appear to be good and clean.
I wonder if anyone else has experienced this and knows the answer! Otherwise it might be back to Raymarine and their eye-watering service charges.
