Boathook
It has packed up and I just get some dashes on the display. This for boat speed, water temp, etc and also effects the true wind display
Unit is an airmar St 800-p120. As it goes into the raymarine seatalk ng system and all the instruments are devoid of the data a supplier thinks that the water temp has packed up which takes out all the speed data. The unit is not longer made and I'm waiting to hear what the replacement is. Boat was launched yesterday so I don't want to much about changing skin fitting at low water, though where I am tidal range is around 0.5 to 1.5 metres.
I see to remember reading that that the water temp input can be 'fooled' to give data to the system there by allowing everything to work apart from a suspect water temp.
Has anyone and suggestions as to where to look such as links, etc ?
Presently on the boat and struggling with Internet due to lousy mobile signal so searching is difficult !
