chubby
Why fiddle with what seems to be working?
All Dabchick`s electronics are current model networked Raymarine kit based on an Axiom 9 MFD and was working fine!
I decided to download the firmware upgrade: all 1.3Gb downloaded via the yard WiFi and it began to install itself, all well except the EV1, the brains of the autopilot, which failed with "timeout" but rather than just being un updated it has sulked and removed itself from the network and the device flashes red rather than steady green! Bxxxger!
Seems this is not unheard of, tomorrows job is to load the updates from PC to mSD card and try again, a pain as the SD card slot is on the back of the axiom which requires a bit of dismantling of the mounting.
The instructions on the Raymarine site seem slightly confusing but hope it works.
Anyone else been though this and what worked apart from taking the EV1 to the dealers or replace (expensive).
As a thread drift this was in preparation for deciding whether to download the Navioinics upgrade as my subscription has expired: if you take a view on chart updates, what do you actually loose apart from auto routing which I never used anyway!
The message seems to be if working leave alone!
