rigpigpaul
Hi All, my C70 has failed. I have the wind, speed and auto instruments. What is the cheapest option to replace the C70 plotter. Can I still keep the instruments.
RPP
RPP
Thanks for the advice. I will check the autopilot type when I am back on the boat then contact Raymarine.What generation C70 is it? What instruments do you have for the wind/speed/depth and also what autopilot?
As if Raymarine you can replace the plotter with a new style and get the instruments to bridge to the new plotter (SEATALK to SEATALK Ng), but unless you have the newer style autopilot then that will not be controllable from the newer Raymarine MFDs.
Hope that makes sense?
Why contact Raymarine ? Just post on here what you have.Thanks for the advice. I will check the autopilot type when I am back on the boat then contact Raymarine.
