raymarine autopilot steers 180degree wrong on wind
sprokkie
27 Feb 2012
Hi,
i connected the nmea outpur of the Hydra2000 FFD to a Actisense NGW-01.
The Raymanrine stng netwrork recoginzed the actisense for different data sources.
Now if i engage the autopilot to steer on the wind, the pilot responses 180 degree wrong.
Using the rayamarine compas it is fine.
We have the EV-100 pilot Evolution EV-100 Tillerpack: ACU-100 p70s, EV-1 Q047 tiller drive.
Is there a setting somewhere ?
I hate Actisense with a passion, and their technical people were real asses to deal with. Worst customer service I've ever seen. This was dealing with my Raymarine ST40 wind instrument, connecting to a Pelagic autopilot. In the end the Pelagic people solved the problems.
Do you have boatbspeed (speed through the water), apparent wind and true wind readings on the sea talk network?
the autopilot uses these 3 to steer on the wind in addition to heading which it provides itself.
Err - the auto pilot uses either the apprent OR the true wind direction in vane mode. Your reply, although it may not be intentiional, suggests it uses all 3 simultaneously
This applies to my B&G instrument system, but probably to most others as well. Is your wind sensor mounted 180 degrees out, and compensated for that by the menu in the wind instrument? If so the the wind instrument will show things correctly but if the autopilot uses the raw data from the wind transducer it will be 180 degrees out.
the acu uses Stw and apparent wind to calculate true wind....it steers using the heading information and samples the choosen wind direction in vane mode to adjust the heading it is using.
