vyv_cox
Ah that could be the problem, I should have done a bit more research before believing the salty old blokes in the boatyard.
This is not quite the model I have but it's pretty similar, the installation diagram is at the bottom:
http://www.vetus-shop.com/vetus-raw-water-strainer-type-140-inlet-dia-19mm-p-1019.html
That looks like the one I have. When I run the engine in the yard using a hose pipe to top up the strainer it definitely drains out of the hole at the bottom going to the pump.
But even plumbing it according to the instructions won't stop air getting in, if it's getting in via the through-hull intake.
But there will be a strainer full of water, as opposed to a short length of tubing, which should be sufficient to prime the pump if it is reasonably unworn.
