Raw water strainer direction of flow
Kelpie
15 May 2005
Afloat
I've recently acquired a secondhand watermaker and want to set it up to do a test run.
I've got a small strainer similar (but not identical) to this:
https://marysvillemarine.com/strainer-barb-pump-jabsco-36400-0000
Question- how much does the flow direction matter with this design? Without buying additional hose and adaptors the only way I can set it up for the test run would have the flow going the opposite direction to the arrow.
And yes I would just buy what I need but it's a Sunday and I'm a long way from a chandlers...
geem
27 Apr 2006
Caribbean
Fine for a test run, its only taking the half bricks out. Your 20 micron pre-filter and 5 micron pre-filter will do the proper filtration. For a test run, i might only plug in a 5 micron pre-fiter anyway
