Petronella
After 6 weeks quarantine it was time to move again. Engine on, water from exhaust as normal. Motor 1 mile. No problem. Increase revs to 2,000. Many alarms scream, water filling engine bilge. Stop engine, close sea cock. Run bilge pumps. Sail back to starting point.
What had happened? The raw water hose downstream of the water pump and connecting the outlet of the oil cooler to the inlet of the heat exchanger had come off. This is a factory fitted hose on a relatively new Beta 75. It has never been removed.
What have I checked? I assumed the problem was downstream of the water pump as the pump was still pumping water into the bilge! However I checked the skin fitting and the strainer, removed the impeller (looked fine), removed the heat exchanger (some minorly blocked tubes but not enough to cause the hose to blow off I would have thought), checked the anti-syphon and finally the exhaust elbow (completely clear).
What else could have caused this? I expected it to be a blocked heat exchanger or exhaust elbow but it seems not. This engine does throw out a huge amount of cooling water so I suppose the heat exchanger could have been the problem (see picture of worst part). It seems strange that it happened after not moving for 6 weeks.
At the moment all I can do is but it back together again and take it up to 2,500 revs for a good while and hope it doesn't recur!
Thanks for your help.
John (S/Y Mehalah)
John (S/Y Mehalah)
