rogerthebodger
Don't forget we have to pay import duty.
Don't we all and we have to pay a higher postage from china than the UK even through we are closer to china that you are may be
In post 4 I said "I see from the data sheet that the alarm won't operate until the flow drops below 1.4 litres/min, which doesn't sound much at all. I'd have thought that a partial restriction in the cooling water could lead to overheating before the flow reduced to 1.4 litres/min."
How is that "criticism"? It's an honest observation, based on facts which I subsequently supplied when you asked for them.
I can't believe that anyone else would perceive this as criticism. If we follow your rules of never commenting on other people's recommendations, the forums will soon die. Is that what you want?
Whatever you say![]()
OP here. The reason I want to be able to sense water flow, or lack thereof, is that I can't otherwise see if water is flowing. I may find that the temperature is rising and I can see that on a guage, but I don't know why.
Oh I dunno, maybe one who has a rudimentary appreciation of punctuation.....I would like to know what kind of Engineer as the term Engineer is a very misused term.
Problem with that is if you get a clog at your intake strainer pressure will not increase so no alarm.Another option is to fit a seawater pressure sender after the pump and before the first heat exchanger. I've done that on both main engines and genatator 2cyl yanmar 2gmf. Normal conditions is 0.3bar, setup a warning at 0.08, alls fine! HUBA sender is plastic bodied and cost 30euro each Iirc.
This way I get a high pressure when heat exchangers are clogged, and low pressure when there's an intake restriction or buggered impeller.
Catch is that all data goes to my custom NMEA2K boxes which do the processing and reporting on the bus...
V
Vas said "Normal conditions is 0.3bar, setup a warning at 0.08"Problem with that is if you get a clog at your intake strainer pressure will not increase so no alarm.
Seems like you are one of the pedantic ones, whose solution is the only correct solution. Chill dude, life is hard enough without extra angst.I would like to know what kind of Engineer as the term Engineer is a very misused term.
Seems like you are one of the pedantic ones, whose solution is the only corrw t solution. Chill dude, life is hard enough without extra angst.
Wow. You really are so very important. We are simply not worthy. All hail.as a retired Chartered Engineer also called Professional Engineers in other countries. who can be help personal accountable for their actions like if a structure falls down and kills someone a Chartered will be charged with culpable homicide as the captain of the costa concordia and the Engineer in charge of a building that fell down and killed several site workers a chartered Engineer needs to be pedantic to ensure his designs are safe and correct.
Also, as a Experienced Engineer I understand there are various ways of doing any job which are safe and correct and protect the users and workers
It's all about accountability for the work you do
Wow. You really are so very important. We are simply not worthy. All hail.![]()
