Greenheart
I'm a total novice here - my dealings with marine engines previously, didn't end happily or profitably. Please dumb-down any explanation you care to give.
As far as I understand it, fresh-water cooling means you use a reservoir of fresh water which will need some cooling unless it's big enough to be seriously burdensome...
...while raw-water cooling just sucks in whatever the boat is floating on, so it needs thorough filtration and the brine attacks the components it encounters, which must therefore be more particularly specified than if they dealt with fresh water...but the advantage is, no need for a cooling system or reservoir.
Is there much more to it than that?
Is one system generally found to be preferable over the other, costs aside?
Thanks.
Thanks.
