Refueler
The reason discs don't stay on the pad is because you have destroyed the velcro either through age or pressing too hard. The pads tend to be expensive to replace so people ( those that are aware) use pad savers which are effectively sacrificial pads that are used in-between the disc and pad and are much cheaper than pads.
I'm sure that I and many others are well aware of why the hook part of the velcro fails ... basically through heat generated in the sanding process.
Yes you can use pad savers - but only BEFORE the hook side gets worn. The 'Hot Glue' trick works with new - not so new and worn out hook side of velcro. Its cheap and quick ... it just works.
