Radar Scanner
AIDY
19 Jan 2004
Muckle Flugga
www.ybw.com
What's the best way of getting it up the mast safely.
Managed to get the old one down somehow without breaking it.....
Anyone got any bright ideas to make it easy to fit. The new one is bigger and heavier /forums/images/graemlins/frown.gif
TIA
Hi, I used a ladder that just reached the spreaders and used a halyard to hoist the scanner and hold it a the correct height while fitting it. I did the whole job single-handed.
Peter
Put a pole on the stern with a brace and attached to the pushpit and put it on that along with anything else you need out of the way. Put the wire inside the pole all the way down into and through the deck along with other wires and you never need b*** around at beginning and end of season again
Put a pole on the stern with a brace and attached to the pushpit and put it on that along with anything else you need out of the way. Put the wire inside the pole all the way down into and through the deck along with other wires and you never need b*** around at beginning and end of season again. Make your own for £100ish or buy a scanstrut for £400ish but you can make a better one yourself.
