Radar reflection
MainlySteam
24 Jul 2003
Re: On reflection
To answer the questions - No, it is not equivalent to a flat surface placed perpendicular to the radar beam. The Radar Cross Section of a target is a comparison of the strength of the reflected signal from a target to the reflected signal from a perfectly reflecting smooth sphere having a cross sectional area of 1 m2. A sphere reflects at an amount that is independant of frequency when the wavelength is small in comparison to the sphere.
However, other shapes do not reflect independantly of frequency - at 3 cm (X Band) a flat reflecting plate about 100 mm square perpendicular has a RCS about 1 m2, but at 10 cm (S Band) it is very much lower, maybe around 0.2 m2. At 3 cm a 1m x 1m plate has a very large RCS of 1000's of m2 and 100'sm2 at 10 cm. I think a flat plate reflects in proportion to its area squared divided by the wavelength squared but I stand to be corrected on that.
So getting back to the 10 m2 sphere that was mentioned in earlier posts it was said that was the area of the surface (so 0.9 m dia) in which case being a sphere its RCS would be roughly the same as its cross sectional area (around 0.6 m2). However, if the 10 m2 quoted was actually meant to be the RCD then one is talking about a very much larger sphere of course.
But, in fact, the requirement of 10m2 is nothing to do with spheres at all, nor the area of anything else either, because I have now checked the UK regulations (which are probably the same as IMO) to see what they say. They say that it is the the RCD that is to be 10 m2.
It can be seen from above that at X band even quite a small plate has a large RCD but for 10 m2 a 100mm square plate would not be big enough - needs to be about square root of 10 times bigger in area I think, if so would need to be about 200 mm square. The purpose of 'hedral shapes is to try and mimic a flat plate in multiple directions, but is not perfectly efficient at doing that, so a 'hedral will have to be considerably bigger than 200 mm square - I guess about the size of the ones one can buy.
Getting back to the RCD being dependant on wavelength, you can see that your analogy of an experiement using a light is incorrect as the wavelength of light is very much less than X Band and also there is nothing to suggest that light will even reflect in the same way (for example a black painted flat plate will reflect radar just as well as an unpainted one, but the same does not apply for light).
Also, at X Band it can be seen that even small areas have quite a large RCD, hence the possibility that Jimi's proposal, adapted to something more realistic than Xmas tinsel, may have some foundation. I suspect there could be a possibility that a rope done as a baggy wrinkle with aluminiumised plastic strips might perform better than some of the plastic cans people buy filled with crumpled up baking foil.
John
Bergman
27 Nov 2002
Window (not chaff please) was many thousands of aluminium foil strips cut to half wavelength of the radar they were meant to block. Each one re-transmitted the received signal effectively giving a strong echo on receiver.
If your tinsel is aluminium and not plastic and you can cut lots of Half wavelenth bits then it should work.
By the by the latest versions detect radar signal and cut the stuff to length automatically. But thats perhaps a bit too much for the average yacht.
Jools_of_Top_Cat
16 Dec 2002
Re: On reflection
Sorry, but talbot is right on this one, window, chaff or little bits of tinsel whichever has, in order to work be of the correct wavelengh and material. I would guess tree tinsel is prolly 95% plastic too.
Also, the shooting it up through a very pistol for example, if you had the correct material would make an enourmous blip on some poor skippers screen, so that you would be somewhere in that quadrant; Or he would be frantically thumping the screen, I also think Norad and the likes would be less than pleased.
<hr width=100% size=1>Julian
<A target="_blank" HREF=http://www.topcatsail.co.uk>Top Cat Homepage</A>
BrendanS
11 Jun 2002
Tesla in Space
Re: On reflection
I can see the very pistol or modified rocket shooting chaff as workable, though do like the paintball gun shooting little balls which release chaff
Would certainly paint a blip which would gain attention.
<hr width=100% size=1>There is no such thing as "fun for the whole family."
jimi
19 Dec 2001
St Neots
Re: On reflection
Listen Matey ... I sincerely hope my tinsel is of the finest metallic quality judging by the price Bev paid for it!! The one from Wilton Garden Centre was very fluffy and cost £5 per metre
<hr width=100% size=1>.. whit way roon should it be again ..
jimi
19 Dec 2001
St Neots
Re: On reflection
As I understand it key principles of radar are:
The better the conductor the greater is the reflection.
The shape of the object will deter-mine how the energy is reflected. If the object has a flat side facing the radar transmitter it will reflect more of the energy back towards the radar than an object of any other shape.
Large objects will reflect more energy than small objects of the same material and shape at the same distance from the transmitter. The object however must be greater than a certain minimum size, in terms of wavelength of the radiated energy, to produce a reasonable reflection of energy. Generally targets must have a size greater than about a quarter of the radar wavelength being used before a detectable echo is received.
This leads me to beleive that good metallic tinsell, well fluffed, and exceeding 2.5cm in width will in fact provide an excellent reflector. Indeed I beleive a 10 metre long bit 5cm wide peice of good metallic tinsel will be seen as a 5cm wide 10m high flat surface from any angle.
bedouin
Re: On reflection
The point of the light analogy is that, however cleverly tuned a radar reflector is, it can never reflect back more energy than is incident upon it. So the very best a radar reflector can do is similar to light falling on mirrors in the same configuration.
So shining light on tinsel will give a good approximation to the pattern of response you would achieve from a similar design of reflector, but little idea of the intensity.
