BlueJasper
Hi, as the boat is new to me I drained some fuel off the primary filter to see if there was any crud in there. I then opened the bleed screw and started pumping the priming button on the filter but I couldn't get any fuel out of the bleed screw. Engine is a Cummins QSB6.7. The tank is lower than the filter if that helps.
Have I missed something obvious here or do I just need to pump longer and will it run OK in this state or will it ultimately stall?
