tamarind
Does anyone know what is the quietest electric head? Apart from the vacuflush which are very expensive. I do have an electric head in my Trader but it is old and sounds like a angry delek!!
But why is it precious? You want them to use loads of it, to keep the black tank system nicely lubricated and clean on the inside. I also want my guests to leave taps running when brushing teeth, and shower for ages, then I have fresh water in the tank everyday+1 for Tecma but why would you want a quiet electric head? I want to know when my guests are flushing precious fresh water down the loo especially when I've asked them to be sparing with it
If I had a watermaker or somebody else to fill the tank for me, I'd be thinking the sameBut why is it precious? You want them to use loads of it, to keep the black tank system nicely lubricated and clean on the inside. I also want my guests to leave taps running when brushing teeth, and shower for ages, then I have fresh water in the tank everyday
Ah I assumed your new ship would have a w/maker. At your new boat's size it would be a great upgrade. You suddenly become self sufficient for ages. Then you only have to tender ashore to take the trash!If I had a watermaker or somebody else to fill the tank for me, I'd be thinking the same
Unfortunately not. The first owner was a cheapskate. You're right though, it would be a worthwile upgrade although, correct me if I'm wrong, I understand you have to use them regularly or not at allAh I assumed your new ship would have a w/maker. At your new boat's size it would be a great upgrade.
Modern ones are easier. Filters are all screw on screw off easy types, and they have auto back flush which means that every week if you don't use the thing it does an automatic 20 minute cycle of rinsing the membrane and flushing the membrane part with new fresh water, using the ship's fresh water supply. This keeps it all fresh and good to go. So all in all they're incredibly easy imhoUnfortunately not. The first owner was a cheapskate. You're right though, it would be a worthwile upgrade although, correct me if I'm wrong, I understand you have to use them regularly or not at all
2. SeaLand Vacuflush. This is good stuff (I've owned several and cleaned em out) and reasonably unlikely to block, but can block when #3 below wouldn't. The flush noise itself is ok, but then afterwards the vacuum pump clunks away for 15 seconds maybe (there is a crank arm pushing/pulling a bellows) and that isn't a nice noise. It can be ok in a bigger boat where the pump is more buried, but is noisy in small boats. Ceramic bowl, and perhaps not the sleekest/prettiest looking
John
Are these the type with the large (ish) ball in the bottom of the loo and a foot pedal on the side of the basin??? I have seen a few of these on boats I am looking at if mine sells
Now you know what problems I have had with my jabsco electric loos/pipes smell etc etc, are these a lot better than the jabsco I have fitted and do they block and if so how hard are they to unblock, I have got very good at unblocking the jabsco unit now :disgust:
Shawn, JFM is truly the Heads King, he could write the Haynes Manual on them, although I'm not sure he is volunteering to deliver a practical training sessionThanks John
If I do get a boat with these then I will give you a shout regards getting them serviced and what to look for, they do sound better than the jabsco I have so that's a bonus for me
cheers
There are no very quiets systems until you get to big yacht systems and HeadHunter type units, but these are suitable in say 30-40m upwards boats
For smaller boats than that you have:
1. Jabsco "quiet flush". As others have said, the noise is amazing and the use of the word "quiet" is a lie. Not great machines imho and not the least liable to block, but only a few £ hundred. Plastic bowl; no ceramics, urgh
3. Tecma - this is the best imho and in the opinion of a lot of great yachtbuilders. Lots of people just wont have anything else. All ceramic bowl, nice styling, looks like a swish house loo, doesn't block. Is a little bit noisy for very few seconds, and nothing like as noisy, nor for as long, as #1 or #2 above
4. Dometic masterflush 8600. This is Dometic's attempt finally to make something as good as Tecma. Pretty good effort, all ceramic, big macerator pump. Looks v good. It is newish on the market and I have not used it or owned it. It is standard fit on squadron 78 now but I specced Tecma on mine. Dometic go on about the fact I uses a litre per flush less water than Tecma and draws 20 amps not 35 at 24v, but I'm not convinced those things are advantages. I like lots of flush water to keep the system running and not getting stuck solids, and I love the ridiculously powerful motors in Tecmas that will macerate logs not just logs. The dometic is reputed to be quiet but I haven't heard one
Price wise all of 2,3,4 are around £1000 per unit
Disagree with the "doesn't block" on the tecmas and when they do they are very difficult to unblock as you have to take the pan out, which involves re doing the silicone etc. You also have to have your head right above the pan, arms around it holding it up as you reach round to undo the jubilee clips. Yuk. Could be mitigated by an access panel in the bulkhead behind. Still agree they are nicest, but your definitive statement is wrong and they are not well designed when they do.
