KajLehtinen
Hi!
More questions on my F43 and its installations.
1. Those of you that has air heater (webasto/ebersprächer), where has Sealine mounted the fuelpickup? My installation that was done when I purchased the boat had the fuel taken from the main fuel line from the port side engine, which worked fine in the beginning but after 2-3 months of use it stopped working and gave error that it had problem with getting fuel.
2. The attached picture, what does the the battery isolation switch do exactly? Kill everything or separate start / aux?
IMAG0349 by KajLehtinen, on Flickr
3. The thing under the white box is, I guess, the relay that joins aux & starter battery banks if one needs that (Crossfeed). But what does the white box usually consist of? I havent opened it yet, but will soon do that I guess.
IMAG0348 by KajLehtinen, on Flickr
4. The black thing, is that a charging diod relay for charging the bowthruster bank?
IMAG0347 by KajLehtinen, on Flickr
