eddystone
On my recently acquired Sadler 32, 86 vintage, as far as I can see a) there is no inspection hatch in the top of the fuel tank or a drain plug on the bottom (there wouldn't be room) b) I haven't found any fuel shut-off between the tank and the first stage of the fuel feed into the VP2002, the water separator/filter (at least it's got one - this was an optional extra on the VP2000 series according to the literature.
The issue with: a) I want drain off a sample of what's in the bottom of the tank - only way I can think of is to attach a long thin plastic hose to the siphon and feed it down through the filler cap - it ought to work as diesel is pretty thin stuff - or should I detach the filler hose form the tank and go in there - that's obviously more fiddly
With regard to: b) On the diesel engine course we were advised to shut off the fuel supply before working on the fuel line - stands to reason really - any suggestions?
