RJJ
Coming back to this thread as an economist and mathematician...(NB, also the OP, and my wife passed with 100pc)Yes. As I have said all along. You are probably outside the hat.
You view the world in terms of what we know, how we interpret what we know, and what we assume.
If we assume our plotting is broadly correct, then we might indeed be 50pc either side of each line. But that's not really the point. Our probability of being "on or near" the line is hight. our three plotted lines work as a team. If, as it turns out, all three lines cross imperceptibly close together (our cocked hat is 1cm square on the ground) then it's fair to say we're probably outside it. But probably pretty close to it. If our three lines cross acceptably close together (1cm on the chart) then there's greater chance we're in it. If our three lines are massively apart, then there's a greater chance we're in the hat, but also that that information is of limited use to us.
Then of course we sensibly superimpose our dead reckoning.
If our DR and fix are wildly apart, or if our fix gives us a massive fix (that, using our experience, is greater than suggested by distance travelled between fixes and the thickness of the pencil) then we are rightly prompted to check our working.
