Cspirit
As part of major refit on my new-to-me LM27, I have fitted an new Jabsco toilet and a holding tank. Both the toilet and the holding tank are above the waterline. The inlet to the toilet has a secondary ball valve by the toilet as a precaution. The discharge hose from the toilet rises further above the waterline then goes to the holding tank. The system is ‘straight through’ I.e. when the toilet seacock is open everything is discharged to sea. When the cock is closed discharge remains in the holding tank and is then emptied by gravity when well offsshore. The holding tank has a 25mm breather vented to the hulll just below deck level.
My question is this. The belt and braces side of my brain tells me that I should install a gate valve on the discharge side of the toilet in the unlikely event of any siphoning. (I have not installed a vented loop in the discharge pipe because there’s no room). However, since the holding tank has a vent, it seem to me that this seacock would be unnecessary since this vent will prevent siphoning in the discharge system.
Is this correct?
Bob
Is this correct?
Bob
