Question 1 on fuel tanks.
madmat99
Active Member
13 Jun 2017
I have two diesel tanks. Both a faded cream coloured plastic. I have put 25 litres of fuel in each and even shining a light through the tank can’t see a level. Pipe from the deck filler is bent round a few things so can’t dip them.
is there something out there I am missing to figure out how much fuel I have?
cheers
mat
You could consider fitting a dip stick, or if you don't like cutting holes in fuel tanks, a U tube, IF the bottom has a drain or fuel outlet.
I have a similar situation. There's a ~2" cover on the plate where all the pipes go in. I'd like to fit fuel gauges, but earlier discussions about their reliability have discouraged me a little. Sight tubes sound like a great idea, but the prospect of draining the tanks (big, at least by rag & stick standards) is a bit daunting! I may well fit a dip stick, as that looks straightforward
cheers
mat
I made a little handheld device for use with plastic tanks that you slide up and down the outside of the tank and a light comes on when it detects the level. Cost about £10 and got the details from this forum years ago. If I can find details I will post...
Edit. The sensor is one like this New Non-contact Tank Water Level Sensor Switch Container Liquid Height Detector | eBay
This is mine running off a 9v battery
www.solocoastalsailing.co.uk
Can you hear a change in noise when you add fuel and the tank is full? Always carry a full 10 or 20 ltr jerry can,
I could see a couple of those on each tank, one at about 1/3 full and one at 1/6, with LEDs at the helm. The ideal would be a bit of electronickery to have both on = green, bottom only = amber and none= red. Maybe it's time for me to start learning Arduino ...
