davidmh
I have a very simple solar panel and a PWM controller, please do not tell me I need a better controller I have what I have.
With the panel and battery connected
1. If I put a multi meter across the input terminals on the controller this will give me the voltage of the panel including cable drop. yes/no
2.If I put the meter across the out terminal that is connected to the battery this will give me the voltage the battery is seeing less any voltage drop. yes/no
3. If 1 is less than about 12.8 or so the battery will not charge the battery with 13.4 or so and it is charging yes/no
4. If the panel is not charging .no sun etc, is the voltage at 2 the real battery voltage or will it be higher due to the residual voltage from charging.
hope this makes sense I just want to know what the multi meter is really telling me
David MH
David MH
