PSS or other seals with a vent tube (disaster avoided)
MoodySabre
24 Oct 2006
Bradwell and Leigh-on-Sea
I went out for a tootle yesterday and came back into my marina and was chatting with visiting boat in the next berth. Suddenly a huge amount of water came gushing out of the bilge pump outlet. There was a lot of water in my bilges either side and under the engine and in bilges. Frantically searching think a cooling water hose has split. Eventually found the culprit to be the vent tube which is held above water level by a cable tie, happily for the past 8 seasons. The tie had broken and the tube dropped below water level. Syphoning the oceans into my boat. Engineering increased three fold.
If I hadn’t been there the boat would have sunk unless someone reported the pump running. No staff to lift the boat at a BH.
Check yours And do you know that your auto bilge pump actually works?
When I fitted a vent tube to my shaft seal I simply took the tube high above water level and put a stainless steel wood screw through it and into a convenient place at the top of the engine room. No way it could ever fall down or slip out of place.
Thanks for the warning. Surprising how many boats have these hoses either as a vent or as a water feed for the propshaft yet, unlike all other hoses to a below water fitting, are not fitted with seacocks/shutoff valves.
www.solocoastalsailing.co.uk
