Protecting copper pipe
snowleopard
16 May 2001
Oxford
I have a fair bit of copper pipe on board - gas lines, fuel lines etc. They all seem prone to corrosion with the surface going green and flaking. I recently replaced a section of gas pipe and on the fitter's advice coated it with varnish. Less than a season later that had also gone green and the surface flaked off.
I have had a couple of fuel lines develop pinhole leaks, possibly as a result of being covered with self-adhesive carpet and now my fridge has lost its coolant, possibly as a result of the pipe between compressor and plate corroding.
What can I coat these pipes with to protect them?
Difficult to coat copper. You need a suitable primer for the job. I dont know what that would be these days.
Maybe a epoxy coating direct onto a clean and abraded surface as for aluminium.??? Have to consult the coatings manufacturers websites
Keep out of contact with seawater the first rule I'd think.
Maybe use plastic coated pipe.
I'm sure someone will come along to explain why it is a bad idea but ....
I installed a 10mm underground copper oil pipe (tank to boiler) at home in 1999 and removed it in 2007 when we built an extension. It was coated in petroleum jelly + passed through an old hosepipe. Looked like new when removed.
Corroding Copper
Just an observation - I had some sections of copper fresh water pipe which had to be replaced at the start of the season (freezing and burst pipes). The pipes were probably no more than domestic quality if that is relevant.
One section was almost paper thin and the copper came away in large, curved but thin flakes that were more reminiscent of iron oxide rust. There was an obvious distinct pink colour to the remaining copper.
The worst section was a vertical length in the back of a cupboard that was firmly secured in the corner i.e. wood on two sides. The cupboard was under the sink but dry, well above the bilge and no where near the batteries.
This is the first time I have ever noticed copper deteriorate like this.
Denso tape has incredible anti-corrosion properties. I have seen ferrous pipework submerged in the North Sea for months emerge bright and shiny after being wrapped in it. The starter motor of my windlass, also ferrous, is wrapped in it with great success.
Its problem is that it is very greasy and not something you would want to handle. I wrap mine in polythene and adhesive tape.
Many builders merchants seem to stock it, or it can be bought on-line.
