Rum_Pirate
When we return I normally take off the engine cowl and give the engine a liberal spraying with CRC Formula 6-56
as a 'guard against corrosion'.
Which reminds me I need to do it this week (first spray for the year).
Bt I am concerned about the following (in red):
Applications Fishing reels, winches, pulleys, metal components, starts wet engines, frees rusted parts, as a corrosion inhibitor
Unit Package Description 16 Ounce Aerosol
Brand CRC
Generic Description 1 Multi Purpose Lubricant
Net Fill 11 Wt Oz
UPC Code 078254060071
Unit Dimensions 7.75H x 2.63W x 2.63D in
Units Per Case 12
Case Dimensions 8.1H x 8.3W x 11.1D in
Cases Per Pallet 133
Case Weight 12 lbs
I 2 of 5 Code 30078254060072
Appearance Clear Blue-Green Liquid
Odor Pleasant
Base Type Petroleum
Flashpoint 170°F
Flammability Flammable
Specific Gravity 0.8187
Plastic Safe Not on all plastics
Evaporation Rate Not Determined
Dielectric Strength 32,500 Volts/Mil
Working Temp -50 to 250°F
Propellant Carbon Dioxide
Aerosol Flammability Level III
360 Valve Yes
DOT Proper Shipping Name Consumer Commodity
VOC % (Federal) 39.1
VOC g/L (Federal) 320.1
VOC Lbs./Gal. (Federal) 2.67
Compliant For CA Yes
VOC Category Multi Purpose Lubricant
CA VOC Limit 50%
OTC VOC Limit 50%
Removal (How To) Remove with petroleum products or mineral spirits.
Brand CRC
Net Fill 11 Wt Oz
Units Per Case 12
Case Weight 12 lbs
Odor Pleasant
Base Type Petroleum
Flashpoint 170°F
360 Valve Yes
CA VOC Limit 50%
OTC VOC Limit 50%
