Propellor dimensions
Sybarite
7 Dec 2002
France
Help please.
I need to get a new prop for a Volvo 18 hp 2002 driving a 30' 3 1/2 ton fin keeler.
The present prop seems to drive the boat well but will not allow the engine to reach its max revs : 3600 rph. It peaks at about 2900 rpm.
Is there a magic formula to determine size and pitch? A plain 2 bladed prop is fine for me.
John.
snowleopard
Oxford
any prop supplier will do the calcs for you or you can get graphs to work it out from. the Boat Data Book is a good thing to have and contains all the graphs.
as a rough idea, an 18 hp engine will need approx 15" dia x 12" pitch.
pvb
UK East Coast
If you\'ve got a few hours to spare...
You could try this <A target="_blank" HREF=http://www.surfbaud.org/zippo/other/surfprop/Introduction/introduction.html>prop calculator</A> program!
Johnjo
8 Sep 2002
Re: If you\'ve got a few hours to spare...
Used the "Prop Calc" program with great success,
when sizing my new propeller.
dickh
8 Feb 2002
Suffolk
I had my prop repitched from 15 x 9 to 15 x 8, added about 400 RPM to the engine speed, from 2800 to 3200. Much better performance as well. A Perkins Perama 17HP with a 2:1 gearbox on a Jaguar 27.
<hr width=100% size=1>dickh
I'd rather be sailing... :) /forums/images/icons/smile.gif
Why do you want to run your engine at max revs? If you are achieving hull speed at lower revs, then surely your engine is running most efficiently?
I use a Volvo MD2020 (3 cyl 20 HP) and find that 2900-3000 rpm is ideal - hull speed. However, I usually motor at 5 knots, so I'm not bothered.
<hr width=100% size=1>Humperdinck
Email: HJ@Seacracker.org
Website: www.seacracker.org
Sybarite
7 Dec 2002
France
Prop is damaged. Better though for engine life to run at slightly higher revs. A diesel needs to run hot.
John
