Moonbeam
I'm going to replace our Volvo lipseal (it's at least 20 years old, not leaking, but has gone stiff). I have not tackled undoing the 25mm shaft from the coupling before, the picture shows the back end of the BukhDV24 on our Westerly Konsort. Has anyone encountered the coupling below? I'm assuming it's just a case of undoing the 4 x nyloc nuts on the bolts clamping the shaft? (Then sliding the shaft backwards etc.) I'm assuming they will be on tight!! I don't have a torque wrench when it comes to doing them back up... so I plan to just do them up as tight as I can? I'm replacing the lipseal with the 'Obritrade' version I have already purchased from ASAP. Any advice from any of you that have tackled this before will be much appreciated. :encouragement:
PS: I'm already looking at this https://coxengineering.sharepoint.com/Pages/Couplings.aspx
