Kashmir
I am the proud owner of two new Brunton Auto-props which I will fit in a couple of weeks. Having recovered from the CC hit I decided to anti-foul the blades (which are a SS variant) with Velox Plus. Rather than use the Velox primer I've opted for Hammerite Special Metals Primer instead on the advice of this forum. On attempting the first coat today I had to abort and wash off the primer. I could tell straight away that it wasn't going to stick as each brush stroke left streaks where the paint hadn't adhered correctly to the metal. I know that preparation is key here and I spent considerable time abrading the surface with an orbital sander and 80 grit paper (see attached photo). I then degreased with 100% acetone. After removing the first coat attempt, instead of using the acetone, I washed the blades in soapy water and dried as recommended by Hammerite themselves. Unfortunately the same happened with the paint wanting to sit on top of the surface.
Am I missing something here? Perhaps the new water based Hammerite SMP is not suitable for stainless steel...
Do you think I will have better results with Marlin's own primer instead?
Thanks for any advice.
