Graham_Wright
2 watts transmission over sea?
14 metre high antenna.
What is the height of the receiving antenna?2 watts transmission over sea?
They would have considerably more power (and antenna height).I picked up ships at 50nM when crossing Biscay. It was quite a reassuring comfort.
We regularly come across boats with AIS that doesn't transmit more than a mile or two. I suspect this is down to bad connections somewhere on their system. We had this a few years ago. A corroded connection on the dedicated masthead antenna
Mine is on a sailboard boom adapted to a mast on the aft rail so about 6 ft above the deck. I have picked up boats over 80 miles away, although incomplete info. I have been contacted by approaching ships at 10 miles range (requesting that I hold my course, or change it, ) I consider 10 miles ample. Being an extending boom I can get it another 2 feet higher, which I do in fog. In the end it really boils down to what is at the other end of the signal.Possibly some of those like mine - antenna is on aft rail - not masthead. Then you are seriously range limited ...
We pick up many yachts presumably with class B AIS normally at circa 6-8nm then occasionally some that only transmit a mile or two. Even picked up one showing it was going the other way and one showing it was going 90 Deg to its actual direction! I think being able to show up on a big ships AIS at 6nm is fairly useful. Not sure how much ability they would have to turn if you only show up a mile or two away. Whether the poor range on some installations is lack of hieght or poor transmission power or both can't really be determined but it makes the AIS pretty useless in some circumstancesMine is on a sailboard boom adapted to a mast on the aft rail so about 6 ft above the deck. I have picked up boats over 80 miles away, although incomplete info. I have been contacted by approaching ships at 10 miles range (requesting that I hold my course, or change it, ) I consider 10 miles ample. Being an extending boom I can get it another 2 feet higher, which I do in fog. In the end it really boils down to what is at the other end of the signal.
