Confused
Have a 5 metre Rib powered by 50 HP Johnson ( power trim & tilt 2000 model ), when I first used the rib I noticed prop slipped when going into any turn or bouncy water. As the prop was not in excellent shape replaced it with a stainless one (15 " secondhand but in very good nick). There appears to be no difference.
I am beginning to think that this is not cavitation but perhaps hull induced ventilation which could be harder to cure. I am unable to lower the outboard any further to see if this helps the problem as it is on its lowest setting.
Now cavitation / ventilation during turning I have heard is quite common, how many have experienced this and how have you been able to cure this very frustrating problem.
The cavitation plate would appear to be about 1" below bottom of hull vee.
All sensible advice gratefully received. I guess what I would like to hear is that I can fit some type of better prop which will cure the problem, but after changing to the stainless steel prop, I am now not convinced and very concerned that this engine is simply not the right combination for my hull.
