Prop Specifications
JSYmartini
29 Dec 2010
Jersey, CI
Hi Guys, I'm after some advice on props:
I've got a pair of bronze props that were for an Aquastar with Volvo TAMD60's (I think), the owner has asked me to try and sell them for him.
I know they're 20x23" did/pitch but I've been told there's a lot more to it re fitment. Different shaft diameters, imperial & metric and also different tapers.
Can anyone tell me how to measure or otherwise identify them accurately in order for me to advertise them properly? (shaft drive if you haven't already guessed)
Many thanks
Tranona
10 Nov 2007
They will be almost certainly imperial diameter, probably around 1 3/4" - just check by measuring the ID at the forward end. The taper should be standard, but again you can check by measuring the id at the outer end and then the length of the taper to give you the rayio.
oldgit
6 Nov 2001
Medway
As a price guide have a look on ebay under bronze propellers or on the Coastal Rides website which has a large selection of similar sized props for sale.Also look on BoatsandOutboards,normall a good selection on there.
There are a couple of companies online which supply new props and reconditioned worth checking .
You will probably need to know if they are right,left handed or both !
To attracted interest any buyer will want to know exactly what you have.
For instance I am searching for a 4 blade prop 22" x 17 Right hand on a 40mm shaft with a taper of 12.
JSYmartini
29 Dec 2010
Jersey, CI
Thanks, I've been told they're probably a 1 in 16 taper, apparently there's 3 tapers in common use. Nothing's ever simple is it!
Just out of interest they're a counter rotating pair and they're 3 blade.
Looks like I'll have to get my Zeus reference book out and the calipers :rolleyes:
moonraker 36
20 Aug 2009
look at the price of second hand bronze prop's on ebay..
they dont fetch much money.
if they are any good as spare's i would just keep them..
