You may find that with no load the engine can limit its Max rpm. When we re engined , the advice was to adjust the prop pitch until the engine will only just reach Max rpm then cruising speed should be around 75% of that. But we have available pitch prop so finding that by iteration was easy. Harder it you have a fixed prop. Then there will be some complex calculations to estimate the right pitch.
I advise to look at the engine manufacturers spec to find the Max rpm under load.
