AllanG
Thanks for all the comments, and it's very interesting to see there are two very differing opinions, which makes my decision more difficult.
Allan
Allan
I am somewhet suprised by Latestarters and Daka's comments above.
I had a problem with a pair of new props ( nickel, aluminium, bronze, (Nibral)) from a well known uk Manufactuer and shafts from the same manufacturer aqualloy 80.
According to the above posters I dont need any shaft anode or electro eliminator?
I put down the problem I had to poor connectivityaccross the R&D coupling, green connections on the shaft brushes or green wire ends ( not tinned at the time) and or no shaft anode.
After that fiasco I put new props from the same manufacturer with the same shafts, re wired electro eliminators replaced, an electrical bridge accross the R&D and shaft anodes and hey presto no further problems on that or further boats with the same set up?
Unfortunately I havent time to conduct a metallurgist report , wish I had as I am intrigued as to establishing exactly what has been supplied.
If you post details of the actual metals (trade names confuse the issue) VicS hopefully will pick up on it being the forum wizard on electrical differences / tolerances allowing for low oxygen water etc
Vetus being a well known supplier supply both good , not needing anodes and cheap which require anodes, a mixture of the two will also require anodes.
Did you keep the knackered ones ?
If a boat has a serious electrical issue anodes will waste away in a month and wouldnt do a lot of good over a year anyway.
