SolentVenture
I take no credit for this piece of advice as it was given to me by an experienced cruiser some years ago. I pass it on as it is so good.
Now you know that prop shaft adodes 'rot' from the inside out so that means that the adode that you once clamped tightly around the shaft becomes loose over time as the internal diameter increases.
A loose anode has a tendancy to run up and down the shaft and can cause all sorts of mayhem to the mountings at each end plus some very worrying nosies.
A simple solution is to clamp hose clips on to your shaft either side of your new anode then as the anode 'rots' it is contained in position and can't go 'walkies' up and down the shaft. Make sure that the hose clips are best quality marine stainless!
