zoidberg
Brass vs stainless.... thin one plus thick one.... securing with cottarpin vs wire locking vs epoxy vs Loctite vs Nyloc....
Pros and contras.....?
I have a stainless nut and split pin on a 316 stainless shaft. The s/s nut is OK - stays done up and I can undo it when needed, but the split pin gets bent and damaged. Maybe because I have a drying mooring? If this is so, then other 'external' locking arrangements will also suffer. I would go for Nyloc or Loctite next time.
Brass castellated secured to the shaft with a split pin through a hole drilled in the shaft. Wind the nut up to the prop boss finger tight if the split pin goes through the hole all well and good if it doesn't back it off until you can insert the split pin.
That's interesting Pete. I have always tightened up castellated nuts with a spanner until fairly tight (say 15 - 20 Nm although not using a torque wrench) and then backed off to fit the pin. Your system is much looser and would probably not even register on a torque wrench scale.
Richard
Just done mine, stainless shaft, bronze prop with a large brass/bronze nut with a 3mm split pin drilled through, followed by a half nut done up tight.
How is the prop locked onto the shaft? If it is keyed, then nut tightness is not critical. If it relies on locking onto a taper, then nut tightness is more important.
