malou
Hello,
The prop of my OVNI 28 (aluminium sailing cruiser) was changed two years ago (said to be copper-aluminium). It already appears to suffer of heavy corrosion. A zinc anode which was fitted a month ago close to the prop is now well damaged, and corrosion on the prop itself continues to grow visibly in a month time.
Suspecting an electric problem, I took few measures (engine stopped) :
Beetween hull and shaft: 600 mV.
Beetween hull and engine (Yanmar 20GM2 changed 1993): 510 mV
Beetween engine and shaft: 90 mV.
Can this cause such corrosion ? What can explain such voltage, and what is to be done to cure?
I’m sure some engineers here can give appreciated help.
Regards.
Olivier.
Regards.
Olivier.
