henryf
Does anyone the UK / South Coast offer a flushing service for marine engine heat exchangers etc. along the lines of this:
Indeed does flushing like that work? On the face of it looks a great service.
We've just had our CAT engines serviced and the fear of God was spread around regarding failing heat exchangers / intercoolers (or aftercoolers for our US cousins). The bill for cleaning came to an impressive £6,300 and change and if we decided to change the aftercoolers as a precaution that would run to a cool £12,000 plus change.
It should be noted at this stage that all engine temperatures are normal and engine power is still more than adequate to pull the old girl out of the water at 30 knots plus with a clean bottom.
I do accept that there is a large element of mark up for using the CAT main dealers here in the UK. Raw water impellers were quoted at £650 each (but not required although once again replacement was gently suggested on the basis of age, belt & braces etc.) They are available in the US for £170 a pair, quite a saving over £1,300. I appreciate you need to ship & pay duty. If you assume £UK for $US landed that would take it to £235 a pair. UK sourced they are about £175 each.
Henry
Henry
