msvob34
HI
Problems #1 DECK LEAK.(right above my bunk aft cabin)
The original deck teak planks have been overlayed with ? and resin and several layers of non slip deck paint.Should I expose the area and (maybe) open a can of worms to find wet rot and worse.or should just overlay again to the toe rail and stop the leak and let the area dry out?
#2 Engine..
I have twin diesels Ford (tractor type) port ok stbd "old Smokey" coupled to these are Parsons gearboxes circa1963..if? I was to replace stbd engine are any modern engines compatable with the parsons G/box?
#3 Sailing
The current Rig is Ketch The jib,the sheets come back to to two pulleys on the wheelhouse and then made up to deck cleats should I fit a track to the deck tween sail and wheelhouse? or other?
Mizzen
the sail is controlled by a sheet and jamming cleat and a small track on the sternpost (any suggestions)or is this ok?
Main
controlled by block and pulley via a small pulley attached to mizzen mast the made up to deck cleat any improvments? also should I add a kicking strap to support a rather long boom . Thks guys & Gals
#2 Engine..
#3 Sailing
Mizzen
Main
