Rivers & creeks
A bit yucky this one! When a poo is done it often won't flush it away, the loo has a feature that when you disconnect the power, the press of the foot switch just pumps out, so we do that over and over but it still won't go and the loo is half full of a swirling poo soup :disgust:
The only way we've sorted it is a bit weird, the flexible hose that goes to the connection to the main outlet pipe (is that where the joker valve is?) if you squeeze that repeatedly on the pump out cycle it eventually clears the blockage. Anyone had a Jabsco 12v lite and had a similar problem? Any other time and about half the time with poo it works a treat, favourite gizmo on the boat so we're very attached to it.
