Ian_Edwards
Hi I have problem with a Lewmar 5kW thruster.
It'll thrust in one direction, but not the other.
When I measure the voltages coming out of the controller in the cockpit I see.
12 volts on both lines when the controller is enabled and when the buttons are pressed, I see 6.3volts on the channel which doesn't work and 4.5 volts on the channel which produces thrust. The voltages are passed to some sort of relay box, which is then connected to a reversing contactor, which switches 12 volts to enable port or starboard thrust.
I've replaced the cockpit control unit, but that doesn't cure the problem.
I looks like there is probably a fault in the relay box, which is completely encapsulated.
Is there anyone out there who understands how these thrusters work and could draw me a circuit diagram (or describe it in words?) with the voltages I'd expect to seem to be a 185TT 12volt?
I've got the installation manual, but that doesn't help.
If I know how the relay box works I could probably knock one using individual relays.
The situation isn't helped by the imminent Easter weekend (difficulty of getting spare) and the position of the bow thruster, which is under the chain locker, in a very tight space with the only access being via a small waterproof hatch.
