mikemcgregor
I have a Cranchi Pelican 32 fitted with twin Volvo Penta D4 225hp and DPH legs.
Started engines ready to move out for lift out for annual servicing. selected reverse on stbd engine, there was a longer than usual pause before gears normally engage then warning buzzer and engine shut down. Started again and same result. I seem to recall seeing on this forum that if you quickly move the gear lever back and forth several times it clears the problem. Tried it and it seem to work at first, however as I was about to make final manoeuvre from the berth it shut down again. Panicked a bit and managed to start up again and made it to the lift out station OK.
Any ideas of what the problem is and how to sort?
