No argument from me I was just making the statement that those were probably all you needed to know.Original and best http://www.animatedknots.com/indexboating.php
Watch it in the mirror maybe!The problem I have with these animated knots is that they extend the bitter end to show the sequence. This gives you no idea how to start.
Probably all the knots you really need to know?
The overhand knot is only worth knowing about when you have to untie one that has tied itself.
I regularly use the truckers hitch, definitely one I wouldn't be without!
http://www.animatedknots.com/truckers/index.php?Categ=scouting&LogoImage=&Website=
I also agree with snowleopard; but would just add that if you are going to do a sheet bend, then go for the double!
The rolling hitch is an essential knot that too many of us can't tie. It's one of those that can save your life (or at least get you out of a tricky situation) - trouble is we don't need them that often, so it's easy to forget!
Also, IMHO, the bowline is used far too much. A good knot for some things, but not all...
And a few you don't! The sheepshank is a useless knot and the timber hitch not far behind. The overhand knot is only worth knowing about when you have to untie one that has tied itself.
Or if abseiling! Its the knot of choice there for the conescenti ;-)
There is absolutely no point in routinely doubling a sheet-bend - the single sheet-bend is one of the most secure bends there is. The point of doubling it is if there is a large difference in the diameter of the ropes being joined. If you don't think a sheet bend is secure enough, tie a carrick bend if the ropes are the same diameter.
Or more lkely it's improved variations the double overhand and the European Death Knot (the astonshingly simple and ddangerous looking, but actually perfectly safe if tied propery, favoured method of joining two rappel lines)
There's no point in doing lots of things we do ;-)
For the sake of one extra turn you get the added security, and besides its easier on the fingers to untie. Good practice in my book to use them routinely!
Yachtmaster examiner asked me what to do if someone trapped arm in winch rope. After knife and luffing (which he said I could not do) he was only happy after I said I'd use rolling hitch to pull tension off line and slip person's arm out.
Sounds like another "only one right answer" idiot as discussed on another thread! If someone's in the midst of being injured then either of your first suggestions are far better than farting around rigging a relieving line!
Nope overhand knot for me & most of the people I know (otherwise double fisherman's). BTW rappel is an americanism not used in Europe!!
