Hurricane
Actually, the mid cabin for me is a show stopper.
I love ours and wouldn't give it up unless I had to.
And the P67, being a 3 cabin boat rather than a 4 cabin that it should be means the mid cabin is massive.
Yep - after the above comments, the P67 does seem to tick a lot of boxes.
I had forgotten to mention that the P67 also has a letterbox passerelle that you can literally forget about until you need it.
Our berths in Sant Carles are pontoon berths so nobody uses passerelles on our pontoon berths anyway.
So we literally forget that we have one.
For the OP
You seem to be considering Princess and I have suggested the P67.
The bad news about the crane.
On ours, it has turned out to be one of those pieces of equipment that has been a difficult to maintain.
Usually, these cranes are made by Opacmare.
When ours was fitted, the heavy duty DC wire connection hadn't been tightened properly and it took years to find it as in intermittent fault.
I have also changed the wire (actually Dynema rope) several times.
I have got it where I want it now but you do need to understand how to strip it down to keep it in good working order.
That said, I wouldn't be without it now.
When I was buying spares for it a couple of years ago, I bought a spare controller (dirt cheap - I found Opacmare's electronics supplier).
Princess supply the boat with one controller and two places where you can plug it in - one on the FB and one in the cockpit.
With an extra controller plugged in, you can use either which saves time.
When we lift the Novurania onto the bathing platform, it is easier to use the cockpit controller.
Conversely, on the FB, i use the FB controller but with two controllers, I can quickly nip between the two.
For the OP
