It looks a bit like a cobra knot http://www.animatedknots.com/cobra/...png&Website=www.animatedknots.com#ScrollPoint
If you play with a bucket of assorted shackles, tension when the over-centre Pelican Hooks are closed can be achieved without resorting to bottlescrews.
Does anyone know the name of this lashing or how to tie it?
I quite like the thought of using it on my new guard wires.
Thanks.
That's what I do, a series of half hitches, a spiral rib - I always thought it was called 'West Country Whipping', but others may correct me.It's just an ordinary round and round lashing which then has a series of half hitches over the top. If all the half hitches are in the same direction you get a spiral rib round the lashing. If alternate half hitches are 'reversed' you get a single straight rib as in the photo.
Not as pretty - and not a fraction as useful, in everyday use and emergencies, as a Pelican Hook.
The excuse for lashings used to be to avoid all round metal and a Quadrantal Error on RDF navigation; as we don't use that now, lashing is a cheap bodge.
If in weather serious enough to need cutting the lashing to recover a MOB, one can well do with the guardwires disabled on at least one whole side of the boat.
Out of all the many modifications I've made to my boat over the years, I rate the Pelican hooks as number 1.
Extremely handy when getting in or out of the tender, and at pontoons the top wire can be clipped back amidships ( with fenders tied to the lower wire ) making cockpit access / egress much easier.
I think the only use of lifelines is when in harbour, when they give some guidance when walking around the deck. It might be hard to sell a boat for offshore use without lines, though.Agree with Seajet.
If you have to have guardrails.
If they are not chest height, then I consider them a tripping hazard (unless the are netted and simply used to stop 'stuff' (not people going overboard).
I prefer a clear deck and a harness.
How about when you handily cut the lashing to recover a MOB then have no guardrails that side in likely heavy weather ?
The modern ones - Seateach chandlery had them last time I enquired for someone - can come with an eye like mine, or can be swaged onto the wire which would be a little neater as long as one got the sums right !
