oldgit
Murv.
If you do oik the pump out of the system for inspection,in addition to the more obvious in-line water filters there is frequently a small little mesh filter secreted away in the inlet pipe flange on pump body.
Probably designed to prevent large lumps of crud entering pump.
A boater of our aquaintance replaced and junked a perfectly good pump.
On later inspection the mesh filter was blocked with chalky deposits, a simple tap dislodged them all and pump functioned normally afterwards.
