Wansworth
Wots that then?Surely, Wind is Delta Pressure or Differential Pressure?????
Differential pressure isn’t wind, it’s the cause of wind. Along with hard boiled eggs and baked beans of course.Wots that then?
Yes but that’s not the pressure being bandied about instead of windDifferential pressure isn’t wind, it’s the cause of wind. Along with hard boiled eggs and baked beans of course.
It certainly is if you have a tri. Most monos don’t spend much time with laminar flow.Surely the aerofoil or Bernoulli effect of a sail relies on the airflow speeding up over the sail and reducing the pressure on the outside curve. With this in mind it is a pressure drop that moves the boats; are they looking to vacuum around the course.
But call a Spade an anchorBreeze, wind, call a spade a spade.
You’ve been peeping in my anchor lockerBut call a Spade an anchor
But more seriously
I agree with your post
Jonathan
Not at all (I'm a bit too far away - though my critics do look over their shoulders.You’ve been peeping in my anchor locker
I am rather bemused by the OP. I don’t understand. Is there a context?Is that wind?
Well exactly,wind is caused by diffences in pressure and my question was addressed too the use of the word pressure in recent commentary on a race.They I assumed to use the word pressure instead of wind hence my inquirey,I thought I had missed something living as I do in darkest GaliciaI am rather bemused by the OP. I don’t understand. Is there a context?
Pressure is a scalar quantity. In meteorology, it is a measure of the weight (force) exerted by the mass of air above the surface of the earth.
Wind is a vector quantity combining the speed (a scalar quantity) of the air moving with the direction of movement.
Wind is caused by differences in pressure.
The idea of using pressure when you mean wind seems stupid. Clearly, I am missing the point of the OP.
I have heard the word “gauge” used in the context of sailing warships having the “Weather gauge,” in other words, being up to wind of another vessel and, therefore, having the tactical advantage. I suppose the same sense could apply in match racing. Are our former colonies living in a different era?
The use of the wor pressure to mean wind still sounds stupid. Are trying to introduce mystique? Are the trying to be clever an, apparently, failing. I have never heard such a nonsensical use of the word pressure. Was it a commentary in English or were you listening to a Spanish commentary? Did you or they miss something in translation?Well exactly,wind is caused by diffences in pressure and my question was addressed too the use of the word pressure in recent commentary on a race.They I assumed to use the word pressure instead of wind hence my inquirey,I thought I had missed something living as I do in darkest Galicia![]()
I wholehearted agreeThe use of the wor pressure to mean wind still sounds stupid. Are trying to introduce mystique? Are the trying to be clever an, apparently, failing. I have never heard such a nonsensical use of the word pressure. Was it a commentary in English or were you listening to a Spanish commentary? Did you or they miss something in translation?
No it was a commentary of the last inshore RTWR by two experts,who bandied about ”pressure”. and race track” as if it was Formula One……..maybe it’s to make it more excitingThe use of the wor pressure to mean wind still sounds stupid. Are trying to introduce mystique? Are the trying to be clever an, apparently, failing. I have never heard such a nonsensical use of the word pressure. Was it a commentary in English or were you listening to a Spanish commentary? Did you or they miss something in translation?
Yes I can see that but the commentary was to all kinds of listeners not all yacht racers…….like mePressure is commonly used in racing to indicate wind. One could argue that if you get in it the pressure on the sail will increase. It's just a simple common colloquialism used in racing. So what? If you don't race don't use it. If your crew prefer another term fine use whatever you agree to. The most important thing in communication is the meaning not the word.
Track is a common term. Your track is what is called course over the ground in sailing terms. In aviation we use track, it's shorter and everyone knows what it means. We might achieve it by steering to a set heading or by setting a course based on a navigation aid but when being guided by the flight management system we are guided to achieve a desired track.
They are just words, the important thing to understand is that both the course and track guidance will correct for drift (leeway) whereas steering to a heading will not.
The words don't matter so long as everyone defines them the same way in the environment you are working in. Don't get me started with True wind vs ground wind!!!![]()
Thankyou,thought I was going madRight then, I'm going to have another go at this one....
Pressure means Force.
The difference between 2 or more of these forces causes wind to Flow.
The Wind flowing over the sails causes us to Sail!!
All them calling pressure, are wrong.
It's Wind.
Simples...isn't it??
