BelleSerene
Dammit - one thing I should have asked, the copy filter unit looks like it comes with 10mm hose tails, which is a bit big for my 5/16 pipe (8mm) - does any of you fine folks know what the thread size is in the unit so that I can order some 8mm hose tails for it?
Damn. I’m sorry, I forgot that detail. I recall I had a similar problem and ASAP Supplies (happen to be in Hamble where our boat is) came to the rescue. I think (please don’t trust me on this) they were a 3/4” screw thread.
[EDIT:] I find a file note from the time in which I had written: Inlet and outlet threads: M14*1.5mm. Don't know if that was correct. Suggest using a marine fittings outfit when the filter arrives.
There’s a loctite product I used to seal the threads. NB you want the version that doesn’t degrade in diesel. It’s on board and I don’t recall but someone on here, or your local chandlery, will advise.
Good luck. The ease of filter changing, and the centrifugal water separator, and the ability to see any crud that’s collected, made it a rewarding change.
BTW, the priming instructions are here: http://www.parker.com/Literature/Racor/Tech_Install/15332_500FG_Turbine_Series.pdf
